SG12
SGC Temp., Humidity, Light sensor
Available Unit(s) 7
    89.00 € 89.00 € 89.0 EUR
    74.17 €
    This sensor provides 3 measurement simultaneity, Humidity, Temperature and Light. It is designed for humid ambience like green-houses up to 95% relative humidity. With 4m PU wire and waterproof connector.
    (The sensor has to be mounted vertically hanging at the cable in a good ventilated room out of direct light or heat sources! Warning indication: The sensor contains sensitive parts, do not hit, let fall or get in contact with water or aerosols. Avoid condensation.
    Technical data's:
    • Measures temperatures from 0°C to +60°C, 0.5°C accuracy from -10°C to +85°C
    • Humidity sensor: +/-3%RH tolerance @55%RH
