Lüftersteuerung mit Transformator?
Wird bei diesem Gerät der Lüfter mit einem Transformator angesteuert oder muss man mit Störgeräuschen rechnen? Kann man ein Stufentransformator gegebenenfalls sinnvoll zwischenschalten um Störgeräusche zu vermeiden?
Hallo
Am SGC selbst sind Transistoren kein Transformator. Es ist jedoch ein Transformator der mit 0-10 /PWM Signal angesteuert werden kann in der Produktion. Dieser kann mit dem https://smartgrowcontroller.com/shop/product/sg18-sgc-0-10v-or-pwm-output-4542 angesteuert werden.
Hier die Beschreibung auf Englisch:
This satellite driver six steps (slave-controller) extend your fan
installation by 350W power and switches between 6-steps. Connect it to
your fan controller (master-controller) with EC output 0-10V or PWM
signal. This satellite is based on transformer (Voltage regulator) and
makes no hum to the fans. It has two RJ45 connector, one for the signal
in and another one signal out that you can connect the next satellite
and extend your AC fan installation always controlled from the master
device.
With 2 Jumpers inside you can choose:
J1 = To switch
between Off or step 1 to keep a minimum speed on the fan, most of cases
you use this on the exhaust fan to avoid odors escaping creating a
negative pressure in the room.
J2 = You can choose to run 1 step behind to create a negative pressure during the controlling for the intake fan.
(Explanation:
If you use Satellite six step transformer you can not connect the
Intake satellite directly to the master fan controller, the Intake and
exhaust satellite will not switch simultaneously together at the same
time. To solve this problem you connect both satellites in series and
tell one of them to run 1 step behind the other one.)
Sizes and technical data's:
Case: WxHxD = 130x92x105mm
Controller: WxHxD = 160x130x105mm
Designed for: 1.5A / 350W / 6-step transformator
Volts: 230V / 50HZ
Protection class: IP54
| Asked: 7/17/22, 9:15 AM |
| Seen: 8814 times |
| Last updated: 7/18/22, 6:07 AM |
