Switch between 2 functions - improvement / howto ?
Version: Unspecified
Theme: Unspecified
on 6/15/21, 4:14 PM • 10,047 views
I have made for all light&switch exits one vegetative timer and one flowering timer depending of the state of one switch button.
how can I do if I want to do the same with fans & related toolbox ?
for example i would like to have different humidity threshold for fan activation depending of veg/flowering stage. or different timer.
it would be better to have one button instead changing each time all parameters in the different toolbox.
the room allows me to duplicate the toolboxes and having different parameters. but then how to connect all the different toolboxes to one intake/exhaust ?
another function same problem. i have a button to force fan idling. how to do to switch between auto and idle ? -> i have one speed controller toolbox to connect to fans and one fan controller toolbox to connect to the same fans...
I have same problem to post a picture to a comment. For now it works on the Post only.
I need to see the how it is designed to be able to follow. Or with a picture or very nice Idea you just make a room in the demo controller. We have check this and are of the opinion that everything works correctly...
G-Systems Engineering ood
Industrial zone 11
BG-8800 Sliven
Bulgaria
Tax ID: BG200487026
Tel. office: +359 879 407 417
BG-Mob.: +359 885 413 696
E-Mail: alain.gressly@gmail.com
Web: www.g-systems.euSent by G-Systems Engineering Ltd. using Odoo.
You have used the function compare and set it to lower, but 0 "zero" is not nothing, 0 in your case is the lower value.
| Asked: 6/15/21, 4:14 PM |
| Seen: 10047 times |
| Last updated: 6/17/21, 9:28 AM |
